Extension import log
Discussion in '3CX Phone System - General' started by netswork, Jan 22, 2013.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Is there a log file generated during an extension import? Mine is failing on every row and I can not figure out why.
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    There is no such log but definitely there is something wrong with the csv file that you are using. It can be the separator (check to be , and not ;). Anyway you can find a guide and templates here: http://www.3cx.com/blog/docs/bulk-extension-import/
