Solved Extension in use when forwarded
Discussion in '3CX Phone System - General' started by AHAutomation, Dec 27, 2016.
  1. AHAutomation
    Mar 31, 2016
    31
    Hi there,
    When we receive a call, i pick it up, i forward the call to my colleague.
    I look in "Number of calls in use / Active Calls" i still see that the my extension is in use.
    When the ring group rings my phone wont ring, because it is in use.....
    With kind regards,
    Peter
  2. AHAutomation
    Mar 31, 2016
    31
    We also encounter when my Colleague forwards the call again, and finally hangs up. The call is still active with my extension number. (This does not happen when my colleague hangs up within the first forwarding)
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Dear AHAutomation,
    Please give us more info about your 3cx Phone System, 3cx Phone clients or IP phones what versions and OS are you using?
  4. AHAutomation
    Mar 31, 2016
    31
    SBC fixed the issues :)
