"Extension is not registered" after login
Discussion in '3CX Phone System - General' started by kfhee, Jan 10, 2013.
  1. kfhee
    Jan 10, 2013
    I am using the 3CX MyPhone softclient and login succesfully using the correct Extension Number and PIN. I can see my status as available. The extnesion status will show "Not Registered"
    When I tried calling another extension I always get this message pop up "Your extension is not registered with 3CX Phone System so calls cannot be made. Make sure your extension is registered and try again"
    I am using the free 3CX PBX.
    Any help as to how I can call another extension?
    10,758
    286
    Does the 3CX log show any "activity" (attempted login), when you first turn on/boot up the 3CX phone extension? There is a debug option in the 3CX phone itself, it should show what is happening during a registration attempt.
    Is this all on the same LAN, or is the extension remote to the 3Cx PBX?
