Extension is unregistered
Discussion in '3CX Phone System - General' started by frikkiee, Aug 4, 2011.
  1. frikkiee
    Aug 4, 2011
    Can someone help with following:
    Extension 9110 is unregistered, removed contact: sip:9110@192.168.1.152:2048;line=gyxv5wxl
    This happens with 3 SNOM 300 phones.
    I hope someone can assist.
    Cheers
  2. frikkiee
    Aug 4, 2011
    I can not provision these phones for some or other reason.
  3. willow
    willow Member
    Mar 1, 2011
    471
    can you ping them from the 3cx server? it sounds like they have timed on the registration. you will need to post a log of them trying to register and make sure that they actually are registering.
  4. frikkiee
    Aug 4, 2011
    Hi. Yes I can ping the phones but there is something wrong with privisioning
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What's the registration period of your SNOM phone?
    Try to set it manually to 1800 seconds (I assume the default is 3600 sec.).
    Regards
