EXTENSION LOCK
Discussion in 'Ideas' started by rslattery, Dec 20, 2016.
  1. rslattery
    Dec 20, 2016
    16
    I would like to see a mass extension lock on all extensions so when you have to delete an extension you can unlock it simply with a confirmation prompt before deletion.
    This would prevent accidental deletion of the wrong extension.
    jlinds likes this.
