Extension login/logout reports
Discussion in '3CX Phone System - General' started by hakana, Nov 3, 2016.
  1. hakana
    Aug 27, 2014
    5
    in v12.5 we can get agent login/lgout reports via webreports, how we can get them in v.15
    thanks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello there,
    Please note that web reports are not available since V14. In V15 you can give users access to the web console so they can generate reports. Just navigate to extensions>> Edit the desired extension>> Rights and enable Allow access to 3CX management console and generate call reports. then the user can login to the management console using the extension number as username and the password found on that page.
    Hope this helps
