Extension management delegation - Disable extension creation
Discussion in '3CX Phone System - General' started by Gregory Marciano, Dec 18, 2017.
  1. Gregory Marciano
    Apr 20, 2017
    7
    Hi everybody,
    Small question regarding the delegation of extensions management.
    For our customers, I would like to let them the possibility to manage the existing extensions, which is possible via the “Rights” of the extension of any user, but I cannot disable the possibility to create new extension…
    Is there a way to only let the customer the ability to edit the existing extensions without any possibility to create a new one?
    Thank's a lot for reading and for help!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Gregory Marciano
    There are 3 rights you can give a user for extension management. The first is to manage its own extension which will only give the user access to see and manage its own extension without the ability to add a new extension.
    The second is to manage extensions in a group but the user then has rights to create an extension.
    And the last is access to all extensions where again the user has rights to create an extension.
    So unfortunately if you want a user to have access to more than his extension then the user will have the ability to create a new extension.
    If you want that to change then you can raise a feature request to the ideas section of the forum where it can be upvoted by other users and evaluated by the appropriate department.
  3. Gregory Marciano
    Apr 20, 2017
    7
    OK, thx Yannis, I will raise that feature request then :).
    I think it's an important one when 3CX is deployed as a cloud model, with a Price per User per month billing...
    Have a nice day
