Extension not available in Queue
Discussion in '3CX Phone System - General' started by sebastian.rojas, Jul 20, 2016.
  1. sebastian.rojas
    May 30, 2016
    14
    i finally installed the 3cx v15, i create the extesion, DID ring groups , all working, but when i create a queue and add extension, it says that is no available, but if a create a ring group for those extension works fine.
    There is another option that i'm missing, i have to enable something in the extension to add it to a queue?
    Best Regard
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    If you are using the Free PBX edition then queues are not available. You will need to upgrade to a commercial edition to be able to use queues.
    Free edition features have changed in V15 compared to V14.
    You can find what is available in the PBX free edition and commercial editions here:
    http://www.3cx.com/phone-system/edition-comparison/
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    maybe it should not be possible to create queues in PBX edition :?:
