Extension number Call Logs
Discussion in '3CX Phone System - General' started by shadjimichael, Dec 11, 2014.
  1. shadjimichael
    Dec 8, 2014
    13
    I want to find the outbound call logs made from a specific extension number few weeks ago.
    I tried the 3CX Log Viewer but it show me only the calls from the last days.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    207
    reporting.
    http://www.3cx.com/support/3cx-web-reports/
  3. shadjimichael
    Dec 8, 2014
    13
    I forgot to mentioned that I know that I have the option of the 3CX web reports but unfortunately is not enough for my case.
    Because from 3CX web reports I can see the extension number and the destination numbers.
    but what I want to know is from what IP address this extension number has been used to make calls to destination numbers.
  4. craigreilly
    Feb 1, 2012
    3,128
    207
    I thought about C:\ProgramData\3CX\Data\Logs\CallHistory but it seems no IP inforamation is here.
    Perhaps the Binary Log Viewer has the Origination IP
  5. shadjimichael
    Dec 8, 2014
    13
    Indeed the Log viewer has the Origination IP but it shows only the recent logs. However, I want oldest logs ie. 3 weeks ago
    It seems that I don't have this option....
    Thank you for your help and response!!
  6. craigreilly
    Feb 1, 2012
    3,128
    207
    The binary logs is what I was referring to. I have like 30+ days of those on my server.
    Not sure if this is a specific setting, but I can not find where I restricted this or extended this timeframe.
  7. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    Craig -
    Not sure, but look in the advanced settings main page and see setting for "keep log files for x days". I do not know if this is for all log files or just the ones used by the server activity log (viewer). Maybe by looking and if you have set to a high number of days it will be an indication.
  8. shadjimichael
    Dec 8, 2014
    13
    "keep log files for x days" was not checked on mine.
    thanks for that info
