Extension out of office bug
Discussion in '3CX Phone System - General' started by rrable, Aug 10, 2010.
  1. rrable
    Jul 13, 2010
    7
    There seems to be an issue when you edit an extension under the office hours tab. You check the "automaticly switch to out of office outside office hours" and it takes affect. When you unselect this option the extension continues to be set as out of office outside of office hours.
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    I have this issue also one or two times. i enabled it again. save the changes. open another extension, back to the first and than disabled the option again, click save. for me this worked, but is not a nice solution.
    i also prefer when extension is switched to available during office hours.
  3. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, can you still replicate with the latest release SP1.
    Thanks and Regards
