Extension remains busy after phone call
Discussion in '3CX Phone System - General' started by OlafS, Jun 8, 2016.
  1. OlafS
    Jun 8, 2016
    Hi everybody,
    After Phonecalls the extension status remains busy untill we disconnect the phonecall in 3CX.
    What can i do to fix this issue?
    Olaf
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Phone make and model or how connected and how provisioned - via 3CX or manually, firmware version and does the trunk show connected as well? Just too little info to go on, but it sounds like it is either not getting the BYE or ignoring it and while that may be the reason, there is still much to know so as to determine the cause.
  3. leejor
    11,086
    325
    in addition...is it a local, or remote extension?
  4. OlafS
    Jun 8, 2016
    It is a Tiptel 3240, Provisioned manually. trunk shows connected, filmware 59.138.5.191, Phone is local
  5. leejor
    11,086
    325
    Does it have the issue if an extension to extension call is made, and the Tiptel hangs up while the other extension remains off hook?
    Does this happen only on calls over one trunk group? Is there a second group[ to test on?
    Is this the only set of this make/model you are using? If not, are others having the same issue?
    Have you attempted to swap out the set itself, if so, does a second set have the same issue? If moved provisioned as another extension, does the problem follow the set?
    Is this a single line or multi line set? If more than one extension, on the set, do all lines have the same problem?
  6. OlafS
    Jun 8, 2016
    On both trunks
    No it's on all the phones
    Still the same problem.
    During the phonecall the extension view says that there are 2 connected calls (see att), after the Phone call 1 is gone, the other one is still connected.
      File size:
      13.3 KB
      487
  7. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    You didn't provide info about one of the questions so that we can understand the scope of the issue:
    Also, the best way to see who is not sending the BYE message would be to capture a call with the issue on Wireshark.
