Extension restrictions
Discussion in '3CX Phone System - General' started by giwm, Apr 28, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Is there any way to restrict an extension to only be allowed to be dialed by a certain extension group or by internal only?
    I have 18 Snom PA1's - one at each of my buildings. There is currently no way I can find to prevent the world from paging in my stores. Or even a disgruntled or prankster employee at one store from paging over another's PA.
    I can't imaging this is NOT available, but if it's not, will a mod please move this to the ideas thread?
    Thanks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @giwm
    Please note that if you navigate to extension settings / Forwarding rules and navigate down to exceptions you can restrict the numbers or extensions that can call that specific extension. You can set a range or separate numbers with a comma and set as destination End call
  3. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    So the easiest would be to end call for everyone and exception out the 4 phones at the store. However, at corporate headquarters, I'm going to have to add 100+ extensions to the exception. Is there any way to add an extension group to the exception list? That would give the ultimate flexibility for all scenarios.
  4. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Also, there are no wildcards... so how would I prevent all external calls to this extension?
  5. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    It appears that with 15.5 SP1, wildcards are now fully accepted in the Exceptions. Cross that item off my wish list. Thank you!
  6. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Hmm... except that you can only divert calls. So you can't do an allow. So for instance, you can't have:
    11* - Received During: All hours - Allow as normal
    * - Received During: All hours - End call
    Back on the wish list. :(
  7. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Also ranges of extensions should be accepted, like 101-153,160-199 in one exception rule.
    Normally you block only unwanted numbers with exception rule (or forward them to secretary, if you want to implement boss-secretary function). Allowed number will ring through to extension.
