Extension Satus, No Password Required
Discussion in '3CX Phone System - General' started by darrellchapman, Apr 10, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    Although this problem shows up in the VoIP Client, its a problem with the server.
    The 3CX VoIP Client, while in desk phone mode, does not require a password to get the extension status from the server. All that's required is that I enter a valid extension number and voila, I can see all extensions.
    The server should require both extension number and voicemail pin to authenticate to get this data.
