Extension settings by group. Ability to insert extension in a group and inherit group settings
Discussion in 'Ideas' started by danilobrambilla, Jun 2, 2017.
Extension settings by group. Ability to insert extension in a group and inherit group settings 5 5 3votes
5/5, 3 votes
  1. danilobrambilla
    Nov 19, 2016
    13
    Instead of set every single extension manually in order to make them setup with the same settings, why not create a group of extensions and then make extensions inherit group settings.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,535
    298
