extension statistic call report
Discussion in '3CX Phone System - General' started by vcy, Aug 12, 2016.
  1. vcy
    vcy
    Aug 3, 2016
    We want to generate an extension statistic call report and we realise that the report is not correct.
    For example if I want to see the report for yesterday I have to run it today at 10am, not earlier.
    If i run a report now from 8am until now, it will show less calls. Its like there is a delay.
    Can you help please? The time zone is correct. The server is showing the correct time and the Call reports (with recordings) are fine.
    Thanks a lot
