Extension status issue - exception occurred ExtStatus
Discussion in '3CX Phone System - General' started by jmani, Feb 8, 2013.
  1. jmani
    Feb 8, 2013
    We are using version 9. Our receptionists are facing some issues after they transferring the call. Sometime they can't receive any calls after they transfer the call to other extension. When I check their extension status, it is saying "dialling". When I try to select and disconnect the call I am getting the follwing error occurred.
    "An exception occurred ExtStatus Error:"
    Please advice how to fix this issue.
    Thanks,
