Extension Statuses
Discussion in '3CX Phone System - General' started by akallistros, Jun 16, 2016.
  1. akallistros
    Jun 16, 2016
    5
    There is no way to see if an extension is registered or unregistered as in previous versions.
    The Dashboard gives you the Extensions Up, but doesn't indicate which are up and which are not.
    The Trunks Up works fine, because it gives the status.
    Other than that, installation was very easy and I also see a lot of enhancements.
    Thank You
    Andy Kallistros
    Clarity Technologies, LLC
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Good point - You can see registered entities in the phones page.. Maybe we can add something to the first column in the extensions page..
