Extension to Extension Distinct Ring with Yealink phones.
Discussion in '3CX Phone System - General' started by wirm, Oct 26, 2014.
  1. wirm
    Oct 26, 2014
    What im trying to do. I have a large home with 2 door stations (voip) and a call box at the gate (voip) the home owner would like to have every device ring differently, so side door would have a ring, front door would have one, gate would have one, and the actual phone system would have another one.
    It seems the Yealink phones support this feature, as you just have to send some tags in the invite header, however, I dont think 3cx can do this, unless im completely wrong.
    My perception of how 3cx sends the info: tag is what type of call it is (i.e. local, international, ivr, etc..) and there is no way for me to tag an Extension with a certain info: header. Is this correct?
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    Re: Extension to Extension Distinct Ring with Yealink phones
    yes you are right, as the PBX converts the callerID to the local format according to the e164 settings in the settings->advanced>e164 section. So for the "internal" calls the PBX does not send the Alert Info.
