Solved Extension Voicemail "*"
Discussion in '3CX Phone System - General' started by mukkacow, Nov 22, 2017.
  1. mukkacow
    Oct 26, 2017
    39
    Hello!
    We have a trunk that direct forward calls to one of our extensions.
    We would like to allow callers to just leave a voice message to the extension voicemail
    Are there a way to disable the "*" and related message ? We do not want callers to be able to press it and get connected with operators.
    At the moment, if they press "*" callers will ear "hold music" and return to the same extension voicemail. We want to avoid this loop.
    Thanks you
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You can't disable pressing '*' and calling operator, but can edit the prompt (in system prompts -- create copy of prompt set), so callers to not hear the option for calling operator.
  3. mukkacow
    Oct 26, 2017
    39
    thanks you @sip.bg
    I have edited the .wav messge and maybe in the future it will be possible to disable it ;-)
    Thanks you
  4. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    Best way of removing the "*" , record your own message for the voicemail instead of the standard system one.
