Extensions Access to the Management Console
Discussion in 'Ideas' started by novatel, Dec 21, 2016.
Extensions Access to the Management Console 5 5 1votes
5/5, 1 vote
  1. novatel
    Nov 23, 2016
    12
    Granted access to a extension of a Group in 3CX PBX can be expanded. Now, in version V.15, only the following options are visible : Extensions, Groups and Call Reported. In this case the extension has no rights to General System Administration. It will be a good idea the options : Contacts, Call log, rights to edit the Group /add or delete group members/ to be managed by the manager of the Group.
    Thank you!
