Extensions Export
Discussion in 'Ideas' started by Futureweb, Nov 9, 2015.
Extensions Export 5 5 4votes
5/5, 4 votes
  1. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    Extension Export should export all Settings configued for that Extensions ... including Rulesets, BLF Data, custom working Hours, ...
    Andreas Schnederle-Wagner
    RogerS likes this.
  2. RogerS
    Dec 12, 2017
    14
    11
    We also expect that the export/import of an extension configuration includes all parameters. As there is currently no extension template, nor possibility to create a new extension based on a existing one, the export/import solution described above could be a workaround.
