Extensions fail to reregister when 3cx restarted
Discussion in '3CX Phone System - General' started by Philco, May 14, 2008.
  1. Philco
    Philco Member
    Nov 10, 2007
    364
    I think this topic may have been discussed before, but what prevents extensions failing to reregister when 3cx has ben restarted (without rebooting the PC).
    If I reboot the devices they will register.
    This ocours with Grandstream devices and SNOM too.
    Phil
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Never seen such behaviour, though I'm restarting my PBX tens times a day.
    I can suppose that phones continue to use nonce's that has been generated and given to them before restart. Actually, my Snom and Grandstream correcty handle this situation.
  3. otaku-oni
    Feb 7, 2007
    8
    Is there anything interesting in the logs?
    Snom have really cool logs in their web interface too . You can see exactly what is going on (attempts + failures) .
  4. Philco
    Philco Member
    Nov 10, 2007
    364
    I've not monitored the network, but I can repeate the situation every time when I remove all the configuration of a server and then reinstall the backup. I then stop and restart the machine and the extensions fail to re register. I even shut the PC down and they still refused to reregister, rebooting the devices all registered ok.
    I'll stick a snom on and see what that tells me.
    Phil
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Phil,
    Since you are a 3CX partner, can i suggest you use the 3CX partner forums for questions that you have? These are monitored by our staff.
  6. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    I had this issue with a netgear 328 router. I changed it to a better router, and it fixed the issue. You may want to just try it. It made no sense to me why, but it worked. Some routers don't do the job like they are suppose to.
    Dan
  7. Philco
    Philco Member
    Nov 10, 2007
    364
    Thanks Dan, it is a netgear 834G router I am using, although I notice that BT Voyager 2110 seems to exibit the same issue. I know some may have reservations about the Voyager series but I find the later models are pretty good.
    I'll have to bear this in mind that I should change the netgear.
    Oddly enough the Snoms are registering ok and its just the Grandstream GXP2000 and ATAs
    I'll do a little more investigation.
    Phil
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    I do not remember exactly, but we met some GS firmwares which doesn't re-register with new "nonce" provided in 407 response. Though my desktop GXP2000 with 1.1.0.14 in it refreshes it correctly.
  9. Philco
    Philco Member
    Nov 10, 2007
    364
    Thanks Archie, I'll downgrade the GXP and see if that cures it..
    Thank you.
    Phil
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    Be warned, that it miss some recentlty added features, for example - BLF.
  11. Philco
    Philco Member
    Nov 10, 2007
    364
    Thanks Archie I remember that.
    Regards
    Phil
  12. Philco
    Philco Member
    Nov 10, 2007
    364
    Of course I cant go back to 1.1.0.14 from latest versions..
    Oh well..
    Phil
