Extensions greater than 5 digits?
Discussion in '3CX Phone System - General' started by Monali, Nov 3, 2008.
  1. Monali
    Nov 3, 2008
    Currently the 3CX PhoneSystem setup allows extension length only upto 5 digits. (contrary to what is posted on the website: unlimited extensions!)
    Is there a way to have extension lengths > 5 (atleast 6?)
    Or am I facing the issue since I am using the free version?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome
    if you will use all 5 digits numbers you will get 89999 extensions
    so I think it's unlimited
    and this for both paid and free versions
  3. Monali
    Nov 3, 2008
    Thanks galal202.
