Extensions not registering
Discussion in '3CX Phone System - General' started by nahidul, Jul 9, 2007.
  1. nahidul
    Jul 9, 2007
    28
    Hello.
    I installed the 3CX VoIP PBX last night, created 02 extensions which worked very good, even with external IP using no-ip. Today, after I restarted my server computer, those 02 extensions are not registering at all. I tried changing the domain ip to local ip. Nothing working, except the Acanac VoIP line is online, registered and the light is green. Any suggestions?
  2. ess
    ess New Member
    Jun 8, 2007
    133
    nahidul,
    Does the server log indicate that there is an AUTH attempt?
    Also, is it possible that you have your server setup for dhcp and it is using a different lan IP now since you rebooted? I realize you are accessing the 3cx web admin console, but perhaps you are doing that via the hostname when the ip changed.
    Keep us updated.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Hi Nahidul ....
    Have a look at server status and start troubleshooting from there. You could also have firewall issues - remember you changed 3CX PBX settings from external (dynamic DNS) to local IP, - phone settings have to be changed too. Check Authentication and credentials of phones and extensions.
  4. nahidul
    Jul 9, 2007
    28
    Hello and thank you for reply.
    The server log does not indicate that there is an AUTH attempt. I am using X-Lite and I changed the domain ip in X-Lite, nothing worked. In my D-Link DI-524 Wireless router, I have assigned a static IP for the server computer.
    Please Help.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I hit this issue today as well.
    -Build 2328
    -Grandstream GXP 2000 Phone under NAT at remote site
    -STUN server OK, trace route to STUN server OK (stun.fwdnet.net)
    -IE can manage the Grandstream GXP 2000 Phone
    -Reset password both at phone and PBX
    At console not found any log for this SIP phone try to register. I had try to power off this phone around 10 times. Then it can register again. I don't know why. All SIP Phones at LAN are no problem found.
  6. nahidul
    Jul 9, 2007
    28
    Hello.
    I am having the same problem after I installed the 3cx in my 2nd computer and restarted that computer. Extensios were working very good but not registering any more after I restarted the server computer.
    My, 02nd problem - VoIP incoming calls are not being received. I can make out bound phone calls using any of the extensions, can not receive.
    Thanks much for help.
  7. silentfun
    silentfun Member
    Dec 11, 2006
    364
    if you use external extension try to use a other stun server not the defauld 3cx one.
    and don
  8. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Silentfun mentionned Firewall issues - I really think there is a firewall issue blocking the pbx - Are all the necessary ports that the 3CX PBX needs to function open? Forwarding rules etc???
    I've read in this post that after a PC restart there were problems. The first thing I would do it check whether all 6 3cx services are up and running - start/run/services.msc . Of course I would need to see some form of logs to try to identify the problem. Extensions can not register for a lot of different reasons.
  9. nahidul
    Jul 9, 2007
    28
    Hello.
    I reinstalled the 3CX software and for some reason it is working great. The problem I am facing now are:
    - No audio either way when I take the X-Lite out side my home network. Extension registers and makes call, but no sound. I set the extension as external line and no luck.
    - VoIP line does not receive incoming calls. It keeps ringing and ringing. I have setup auto attendant and no luck.
    - I need help with STUN server. I saw two locations to put that in 3CX PBX. My VoIP provider e-mailed me a STUN server, so I guess it goes in VoIP line. What should I use for 3CX General Settings -> STUN Server options? Currently I have stun.3cx.com
    Please advice.
    Some of the Log:
    11:51:10.296 StratLink::eek:nHangUp [CM104001] Call(6): Ln:10000@Acanac hung up call; cause: BYE; from IP:66.49.255.42
    11:50:49.671 MediaServerReporting::DTMFhandler [MS211000] Call(6) Ln:10000@Acanac: DTMF (RTP) from 66.49.255.42:19884 arrived. in-band DTMF tone detection is turned off.
    11:50:46.328 CallLegImpl::eek:nConnected [CM103001] Call(6): Created audio channel for Ln:10000@Acanac (66.49.255.42:19884) with Media Server (192.168.0.101:9000)
    11:50:46.312 StratInOut::eek:nConnected [CM104005] Call(6): Setup completed for call from Ext.102 to Ln:10000@Acanac
    11:50:46.312 CallLegImpl::eek:nConnected [CM103001] Call(6): Created audio channel for Ext.102 (192.168.0.104:64028) with Media Server (192.168.0.101:63376)
    11:50:43.609 CallConf::eek:nProvisional [CM103003] Call(6): Ln:10000@Acanac is ringing
    11:50:36.984 MediaServerReporting::STUN [MS101003] Call(6) Ln:10000@Acanac: Possible firewall problem. Address mapping failed on STUN server 66.7.238.210:3478 for local address ":9000"
    11:50:30.859 CallConf::eek:nIncoming [CM103002] Call(6): Incoming call from 102 (Ext.102) to sip:915064407777@nahid.no-ip.info
    11:50:20.437 ServRegs::eek:nAdd [CM113002] Registered: Ext.102
    Thank you inadvance for help.
  10. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Try to Bind to media server
    First try solving these issues and then try making a call from the start.
    Keep STUN.3CX.COM as a stun server in the General Settings Page.
    If the Voip Provider is listed as a template in the ADD VoIP provider page, then edit nothing and leave the VoIP line as it is generated. Those are pre configured settings that are tested to work. If the VoIP provider is not listed as a template then enter the Stun Server in the Voip Line Page as it was given to you.
    Make sure that the Ports for stun requests are open - there seems to be a firewall issue blocking your stun server requests. Open port 3478 on the firewall in and out going.
  11. nahidul
    Jul 9, 2007
    28
    Hello and thank you for your help.
    I have tried to open 03 different ports in my D-Link DI-524 Wireless router. Not sure wheather I got it right or not. Here is what I have done: http://people.stu.ca/~nahid/others/3cx/D-Link_DI524_Firewall.pdf . Please note 3cx is installed in 192.168.0.101 computer. I tried to open the ports 7000, 9000 and 3478.
    Here is a current log for you to look at: http://people.stu.ca/~nahid/others/3cx/3CX_Log_18July2007.pdf .
    At this moment I am trying to get the Auto Attendant to pick up incoming calls.
    Thank you again for your help.
  12. silentfun
    silentfun Member
    Dec 11, 2006
    364
    - if you take out of your network - insure you have checked "extern"
    - no autio is often a problem with codecs. but x-lite usualy don
  13. nahidul
    Jul 9, 2007
    28
    Hello.
    I got the incoming VoIP calls working. But I am getting 03 errors:
    01) 17:02:18.187 MediaServerReporting::STUN [MS101003] Call(23) Ln:10000@Acanac: Possible firewall problem. Address mapping failed on STUN server 66.7.238.210:3478 for local address ":9002"
    02) 17:02:07.406 MediaServerReporting::DTMFhandler [MS211000] Call(23) Ln:10000@Acanac: DTMF (RTP) from 66.49.255.42:18324 arrived. in-band DTMF tone detection is turned off.
    03) Error loading license.
