Extensions picking other phones incoming calls/messages
Discussion in '3CX Phone System - General' started by Tony Brown, Mar 16, 2018.
  1. Tony Brown
    Mar 16, 2018
    A couple of colleagues are reporting that their extensions are picking up other people's calls and messages.
    I was wondering, does the 3CX phone system operate in a way where if certain calls are made direct to extensions, messages or transfers cannot be made (available or DND). Does the 3CX phone system automatically bounce elsewhere to other extensions?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Tony Brown
    The PBX will build a specific call flow based on your configuration. A call routed between extensions is very possible, but this won't be random at all, if this is what you mean. It will follow a predefined path based on your setup and configuration.
  3. leejor
    11,083
    325
    If one of these calls happens, have a look at the 3CX Activity Log. It will show the progress of the call through the PBX, and why it went where it did. Everything working as it should (no hardware faults or software corruption), calls route to a an extension because rules and events, that were created, cause this to happen, nothing is random.
