Extensions Unregistering and re-registerin every hour or so.
Discussion in '3CX Phone System - General' started by leo777, Jul 2, 2012.
  1. leo777
    Jul 2, 2012
    I have been experiencing a very strange behavior with 3CX for the past two days; extensions such as DialCode, SP3, SP5,SP7, and all of my 22 phone extensions, are unregistering and re-registering on their own every hour of so. In addition, calls are breaking up, and digital receptionist does not work properly. I have noticed that accessing the web interface takes longer then usual now, in many cases, I can't even access it. I have rebooted the server (Which is a virtual host, running on Hyper V stand Alone server), and I also noticed that all 3cx services needed to be started manually, there is also a delays of about 5 seconds when making a call, or when a call hits the 3CX server.
    Any help will be greatly appreciated, or if there is another post that addresses this same issue, please point me to it.
    Thanks,
    in advance for your help.
  2. leo777
    Jul 2, 2012
    Re: Extensions Unregistering and re-registerin every hour or
    Here is an update with some server activity log:
    22:20:00.345 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 10.0.0.54:5060 UDP target domain=unspecified mFlowKey=0 ]
    22:20:00.345 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 10.0.0.79:5060 UDP target domain=unspecified mFlowKey=0 ]
    22:19:55.162 Currently active calls [none]
    22:19:24.182 Currently active calls [none]
    22:19:04.625 [CM503008]: Call(18): Call is terminated
    22:18:52.443 Currently active calls - 1: [18]
    22:18:33.066 Session 53782 of leg C:18.1 is confirmed
    22:18:32.959 [CM503007]: Call(18): Device joined: sip:807@127.0.0.1:40600;rinstance=f0f2c3b33139a448
    22:18:32.958 [CM503007]: Call(18): Device joined: sip:10001@10.0.0.236:5060
    22:18:32.957 [MS210005] C:18.1:Answer provided. Connection(proxy mode):10.0.0.54:7080(7081)
    22:18:32.954 [MS210001] C:18.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40640(40641)
    22:18:32.948 Remote SDP is set for legC:18.2
    22:18:32.948 [CM505001]: Ext.807: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:807@127.0.0.1:5060]
    22:18:32.948 [CM503002]: Call(18): Alerting sip:807@127.0.0.1:40600;rinstance=f0f2c3b33139a448
    22:18:32.795 [CM503025]: Call(18): Calling Ext:Ext.807@[Dev:sip:807@127.0.0.1:40600;rinstance=f0f2c3b33139a448]
    22:18:32.794 [MS210004] C:18.2:Offer provided. Connection(proxy mode): 127.0.0.1:7082(7083)
    22:18:32.759 [CM503004]: Call(18): Route 1: Ext:Ext.807@[Dev:sip:807@127.0.0.1:40600;rinstance=f0f2c3b33139a448]
    22:18:32.759 [CM503010]: Making route(s) to <sip:807@10.0.0.54:5060>
    22:18:32.759 [MS210000] C:18.1:Offer received. RTP connection: 10.0.0.236:5104(5105)
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    I really do not see anything in the log that shows an issue. I show a call coming in and being handled quite quickly (under 1 sec.). Some of what you describe is more typical of a congested network, and/or perhaps a processor that may be struggling. Do extension to extension calls have the audio breakup?
    When I indicate a congested network, that is to say a network that does not allow the packets to flow "freely". It could indeed be that traffic is flooding in or that you may have a defective NIC, switch. router or firewall (software or hardward) that needs looking into. Maybe a setting was changed. If it is really bad, this could explain some of the phones having registration issues, but I am uncertain why the parking spaces would.
    Look at the perfomance tab on your task manager and assess what it sees. Also look at the 3CX server event log (not the activity) and see if it provides additional detail and you may also need to check the event viewer.
