- Joined
- May 10, 2007
- Messages
- 1
- Reaction score
- 0
i've spent endless hrs trying to get this to work, but simply cannot get extentions to register. when making an outgoing call via SJPhone, the following log is made: (hope it helps to troubleshoot). CAM ANYONE HELP?!?
23:32:30.359 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '155'; Rline: '155'; Contact: '30117491*203'
23:28:29.296 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '02085072007'; Rline: '02085072007'; Contact: '30117491*203'
23:28:22.031 ClientRegs:nSuccess Registration of sip:[email protected] is successful
23:28:21.843 ExtLine::Register Send registration for "08704789050"<sip:[email protected]>
23:28:21.843 ExtLine::Register Use External IP for device line registration DN='10000' device='voipfone.co.uk'
23:28:10.281 ClientRegs:nSuccess Registration of sip:[email protected] is successful
23:28:10.046 ExtLine::Register Send registration for "08704789050"<sip:[email protected]>
23:28:10.046 ExtLine::Register Use External IP for device line registration DN='10000' device='voipfone.co.uk'
23:27:49.187 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '02085072007'; Rline: '02085072007'; Contact: '30117491*203'
23:27:40.312 ClientRegs:nSuccess Registration of sip:[email protected] is successful
23:27:40.078 ExtLine::Register Send registration for "08704789050"<sip:[email protected]>
23:27:40.078 ExtLine::Register Use External IP for device line registration DN='10000' device='voipfone.co.uk'
23:24:38.031 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '02085072007'; Rline: '02085072007'; Contact: '30117491*203'
23:24:20.796 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '155'; Rline: '155'; Contact: '30117491*203'
23:22:54.093 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '155'; Rline: '155'; Contact: '30117491*203'
23:21:48.453 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '155'; Rline: '155'; Contact: '30117491*203'
23:20:58.890 Endpoint::findSource Can not find source by following specs: Contact IP: '127.0.0.1'; From: '30117491*203'; To: '155'; Rline: '155'; Contact: '30117491*203'
23:20:36.718 ListenConnect SL: connected homepc:0/PHPExtension_0 at [homepc]/PHPExtension_0
23:18:34.406 ClientRegs:nSuccess Registration of sip:[email protected] is successful
23:18:30.390 ExtLine::Register Send registration for "08704789050"<sip:[email protected]>
23:18:30.390 ExtLine::Register Use External IP for device line registration DN='10000' device='voipfone.co.uk'
23:18:24.625 StunClient:rocess STUN resolved external
