Extention will overwritten from the provisioning template
Discussion in '3CX Phone System - General' started by emion, Aug 3, 2011.
  1. emion
    May 2, 2011
    3cx v10, SP2.
    SPA525G without Attendant Console!
    Berofix box.
    If I added (on web interface) extentions to the line key (for example 200, 300, 400 and 500, see screenshot), the extention will overwritten from the provisioning template every 86400 seconds (by standard setting).
    I want, that the extention 200 stays. How can I achieve this?
    PS: it works fine with Attendant Console, if I have configured the template on the 3cx-bpx-web-interface under:
    phone provisioning -> BLF (Busy Lamp Fields)
    Thanks for your help :)
