External callers lose audio.
Discussion in '3CX Phone System - General' started by jsadan, Jun 14, 2010.
  1. jsadan
    May 3, 2010
    91
    I have been told that while my employees are on the phone the customer cannot hear them for a couple of seconds, 10-15 seconds and then they can hear again. The phone they use is the SPA-942
    Anyone have any ideas on why this would occur?
  2. carolinainnovative
    May 4, 2009
    369
    6
    What kind of setup are we talking about here? VoIP provider? "Hard line" connected to a patton or something?
    Anything interesting in the logs when this occurs?
  3. jsadan
    May 3, 2010
    91
    Thank you for your reply salter,
    3CX Free Version
    VoIP Provider: Teliax
    Nothing funny in the logs.
    The machine has two NIC's, 1 of them is on our .10 network (Our VoIP phone netwrok) the other is on our .100 network (Our computer network) Ive tried disabling the .100 network and seeing if that changed anything. Nothing so far.
  4. carolinainnovative
    May 4, 2009
    369
    6
    Ok just so I get a complete picture - you're using the 3rd octet for different subnets in your private network? ie 10.0.X.0/24, where X is, in this case, 10 or 100?
    Just making sure I understand.
    Inbound/outbound?
    What kind of firewall?
    Do you have any WireShark traces?
    Have you checked with Teliax to see if they can offer any ideas?
  5. jsadan
    May 3, 2010
    91
    Yes you are correct.
    Inbound
    SonicWall
    I do not have any WireShark traces.
    I have recently contacted our VoIP Provider about a different issue and ran a full check on our phones and said everything was running fine.
  6. carolinainnovative
    May 4, 2009
    369
    6
    Lots of people have had lots of problems with Sonicwall && VoIP. Some say it has gotten better - I don't know. Is it something that just STARTED happening or has it been going on for a while?
    If it is happening regularly enough to reproduce, I'd recommend trying to run wireshark on it and get some traces. That might help identify the issue.
    Otherwise, I'm going to say it is something on the SonicWall... though partially my guess at that is b/c sonicwall is an easy target with voip issues.
    Perhaps a 3cx engineer can chime in?
  7. jsadan
    May 3, 2010
    91
    I was just googling the error and yes you are right. There are a lot of common cases with SonicWall being a issue with VoIP phones. I am going to double check and make sure all PBX ports are not blocked and run the firewall checker and see if I come up with anything.
    I appreciate all the help!
