ampminfo
- Joined
- Mar 9, 2010
- Messages
- 1
- Reaction score
- 0
Hi.
I notice a small problem that I can't firure out about making call from an external phone to 3cx phone system inside the mailbox option 9 and option 3 (make external call menu)
If I call from my landline to my system and use this option by calling the number I want using "9 xxx xxx xxxx" (no space here) the line ring at the other end without problem but If I call from my cellular phone to my 3cx system and do the same I get a "failed to transfer call"
Here the complete steps
1) call my 3x system phone number
2) connect to voicemail with "999"
3) when ask for extension...I provide mine "101"
4) when ask for password...I provide it "...."
5) from menu...I provide option "9"
6) from second menu ... I provide option "3" (make a call)
7) I provide the number stating with "9" and the number xxxyyyzzzz
As I said...from landline no problem but from my cellular I got the "failed to transfer"
15:39:25.878 [CM503008]: Call(25): Call is terminated
15:39:14.003 [CM503016]: Call(25): Attempt to reach <sip:[email protected]:5060;user=undefined> failed. Reason: Not Found15:39:14.003 [CM503014]: Call(25): No known route to target: <sip:[email protected]:5060;user=undefined>
15:39:14.003 [CM505003]: Provider:[unlimitel xxxxxxxxxx ] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:[email protected]:5060]
15:38:54.862 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 94.228.101.70:3478 over Transport 192.168.200.10:5060
15:38:34.128 [CM503007]: Call(25): Device joined: sip:[email protected]:40600;rinstance=1667df796877f819
15:38:33.972 [CM503025]: Call(25): Calling Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=1667df796877f819]
15:38:33.909 [CM503004]: Call(25): Route 1: Ext:Ext.999@[Dev:sip:[email protected]:40600;rinstance=1667df796877f819]
15:38:33.909 [CM505003]: Provider:[unlimitel xxxxxxxxxx ] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:[email protected]:5060]
15:38:28.222 [MS211000] C:25.1: aaa.bbb.ccc.ddd:16792 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
