External Calls (PUSH) to 3CX client on Android V12 dont work
Discussion in 'Android' started by AlexT, Oct 12, 2013.
  1. AlexT
    Oct 12, 2013
    My 3CX client on Android V12 work fine with Presence, Chat and local Cals (PUSH).
    But external Cals dont work (PUSH). They are caming to mobile.
    Info:
    3CX client on Android V12 with tunnel
    All configurations done by e-mail
    Mobile HTC ONE S
    3CX Phone System 12 sp1
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Re: External Calls (PUSH) to 3CX client on Android V12 dont
    Going to mobile?
    The PBX either sees the extension is not at Available (or Available 2).. or sees no handset/phone registered to the extension.
    Either way, sounds like a forwarding rule is triggering.
    OR.. you configured your extension for Internet calls in the SIP config on Android.. so it may be ringing first. Hmm.. haven't tried that one..
    Check a call to your extension in the PBX log to see how it is choosing to route the call.. and to see that your tunneled phone is registered.
  3. AlexT
    Oct 12, 2013
    I install v12 SP2 and now its working: external and internal Calls (PUSH) wake up mobile (3cx client) and we can talk.
