KerryG said:Correct, you have to change that setting for each extension that you want to be able to connect outside your network. This is an important security feature.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
