External connections to 3CX won't maintain presence
Discussion in '3CX Phone System - General' started by Gerald Warren, Nov 13, 2015.
  1. Gerald Warren
    Oct 22, 2015
    19
    Greetings!
    We have recently implemented a 3CX phone system in our company with Yealink T23G phones. We've worked out many internal issues, however still have an issue with external connections.
    To date, any 3CXPhone mobile or desktop client I have attempted to connect back to the 3CX system will display a constantly alternating "Connecting" and then "Time Out" in the presence field of the application. The 3CXPhone shows as on hook, but the presence window, voicemail, call history etc. are all blank. Additionally, the ports for Apple and Google push fail when running the firewall checker from the 3CX phone system, even though the ports are open within the WatchGuard firewall policy for 3CX.
    Any help on this would be greatly appreciated.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    The "call control" component is using SIP.. UDP 5060.
    The "presence" component is using whatever your web service is set to.. TCP 80/5000. If that isn't forwarded/allowed, you'll get registration but no presence.
    Similar when UDP 9000-90xx isn't forwarding/opened and you get no media (typically no audio) coming in.
  3. Gerald Warren
    Oct 22, 2015
    19
    Ian,
    Thanks for the reply.All those ports are set to be open for the 3CX firewall policy.
  4. Gerald Warren
    Oct 22, 2015
    19
    Any further help on this would be greatly appreciated!
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    check windows firewall. 3cx doesn't always open up all the required ports on install.
  6. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Check if your firewall has SIP ALG enabled. If so, then disable.
    Allen
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Which version of 3cx are you using? Do you have the Yealinks set to keep alive?
  8. Gerald Warren
    Oct 22, 2015
    19
    Verified that Windows Firewall on the 3CX PC is disabled.
  9. Gerald Warren
    Oct 22, 2015
    19
    The WatchGuard software doesn't have a global SIP ALG setting. It has to be set up within a firewall policy and I do not have a policy with this setting enabled.
  10. Gerald Warren
    Oct 22, 2015
    19
    3CX ver 13 SP1 build 45826.228
    I'm unsure if the Yealink are set to keep alive, but the issue is with the 3CXPhone app on iPhones and computers when they attempt to connect outside of the office LAN or BOVPN.
