external extension audio problem
Discussion in '3CX Phone System - General' started by fala70, Sep 28, 2007.
  1. fala70
    Aug 10, 2007
    23
    I've an audio problem when I call an external extension. The audio work good only a direction, from internal extension lan to external extension. From external to internal not work.
    The port forworded side server are all correct (192.168.1.100 is the server):
    1 sip 5060 5061 192.168.1.100
    2 RTP 8000 8000 192.168.1.100
    3 HTTP_Server 80 80 192.168.0.100
    4 esterne 9000 9500 192.168.1.100
    5 3CX WEB SERVER 5480 5482 192.168.1.100
    6 3CX 3478 3478 192.168.1.100
    7 - 5072 5072 192.168.1.100
    8 - 8888 8888 192.168.0.100
    9 - 3456 3456 192.168.0.100
    10 - 4662 4662 192.168.1.105
    11 - 4672 4672 192.168.1.105
    12 - 4711 4711 192.168.1.101
    13 3CX 7000 7499 192.168.1.100
    14 3cx 10000 20000 192.168.1.100
    side external extension I use a hardware phone directly connected to a pc with a modem, without router and firewall.
    this is the log of a call, 100 is then external extension, 101 is the normal extension.
    18:40:52.406 StratLink::eek:nHangUp [CM104001] Call(47): Ext.100 hung up call; cause: BYE; from IP:217.202.74.235
    18:40:27.937 CallLegImpl::eek:nConnected [CM103001] Call(47): Created audio channel for Ext.100 (217.202.74.235:62882) with third party (192.168.1.102:9000)
    18:40:27.937 StratInOut::eek:nConnected [CM104005] Call(47): Setup completed for call from Ext.101 to Ext.100
    18:40:27.937 CallLegImpl::eek:nConnected [CM103001] Call(47): Created audio channel for Ext.101 (192.168.1.102:9000) with third party (217.202.74.235:62882)
    18:40:24.578 CallConf::eek:nProvisional [CM103003] Call(47): Ext.100 is ringing
    18:40:21.984 CallConf::eek:nIncoming [CM103002] Call(47): Incoming call from 101 (Ext.101) to sip:100@192.168.1.100:5060
    Any idea. Thanks to all.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please ticked following option for all external extension(s) under Other options at extension setting:
    Extension is external
    Bind to Media Server
    For extensions at same LAN or VPN just ticked "Bind to Media Server"
  3. fala70
    Aug 10, 2007
    23
    Now I've activate all two options for both extension. There is again the problem. Now no audio for all direction
    07:46:57.640 MediaServerReporting::RTPReceiver [MS105000] Call(4) Ext.100: No RTP packets were received on 00000008@:remoteAddr=217.202.104.128:54200,extAddr=87.6.59.135:10233,localAddr=0.0.0.0:9010
    07:46:53.578 StratLink::eek:nHangUp [CM104001] Call(4): Ext.100 hung up call; cause: BYE; reason: SIP;description="User Hung Up"
    07:46:34.140 ServRegs::eek:nAdd [CM113002] Registered: Ext.101
    07:46:32.406 ServRegs::checkExpiration [CM113000] Registration for sip:101@192.168.1.100:5060 has expired
    07:46:25.531 CallLegImpl::eek:nConnected [CM103001] Call(4): Created audio channel for Ext.100 (217.202.104.128:54200) with Media Server (87.6.59.135:10233)
    07:46:25.531 StratInOut::eek:nConnected [CM104005] Call(4): Setup completed for call from Ext.101 to Ext.100
    07:46:25.531 CallLegImpl::eek:nConnected [CM103001] Call(4): Created audio channel for Ext.101 (192.168.1.102:9000) with Media Server (87.6.59.135:10231)
    07:46:21.546 CallConf::eek:nProvisional [CM103003] Call(4): Ext.100 is ringing
    07:46:16.968 CallConf::eek:nIncoming [CM103002] Call(4): Incoming call from 101 (Ext.101) to sip:100@192.168.1.100:5060
  4. fala70
    Aug 10, 2007
    23
    I tried also to ticked extension is external only for one, the audio work on for a direction, and this is the log:
    07:59:02.921 MediaServerReporting::RTPReceiver [MS105000] Call(6) Ext.100: No RTP packets were received on 0000000C@:remoteAddr=217.202.104.128:48488,extAddr=87.6.59.135:10299,localAddr=0.0.0.0:9016
    07:59:02.906 StratLink::eek:nHangUp [CM104001] Call(6): Ext.101 hung up call; cause: BYE; from IP:192.168.1.102
    07:58:51.062 CallLegImpl::eek:nConnected [CM103001] Call(6): Created audio channel for Ext.100 (217.202.104.128:48488) with Media Server (87.6.59.135:10299)
    07:58:51.062 StratInOut::eek:nConnected [CM104005] Call(6): Setup completed for call from Ext.101 to Ext.100
    07:58:51.062 CallLegImpl::eek:nConnected [CM103001] Call(6): Created audio channel for Ext.101 (192.168.1.102:9000) with Media Server (192.168.1.100:7004)
    07:58:49.640 CallConf::eek:nProvisional [CM103003] Call(6): Ext.100 is ringing
    07:58:45.734 CallConf::eek:nIncoming [CM103002] Call(6): Incoming call from 101 (Ext.101) to sip:100@192.168.1.100:5060
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Internal to external, audio OK. External to internal, no audio. Must be ports.
    http://www.3cx.com/forums/the-portforwarding-faq-hope-this-gets-a-sticky-1697.html
    Are you ensuring TCP / UDP as described? And for RTP which are you using?
  6. fala70
    Aug 10, 2007
    23
    Yes I am sure. I am using 9000-9005
