External extension not disconnecting
Discussion in '3CX Phone System - General' started by jparisi, Dec 24, 2007.
  1. jparisi
    Oct 1, 2007
    92
    I have an external extension that seems to be working ok placing calls, receiving calls, and calling other extentions, but when I hang up the "Line Status" screen shows the extension as still connected.
    Another issue, I cannot call the voicemail extension of 999. It says connected, but I don't hear anything and trying to dial the VM extension I want crashes the IVR service.
    Here are some log entries:
    09:46:10.906 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    09:46:09.937 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    09:46:08.937 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    09:46:07.968 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    09:46:07.968 MediaServerReporting::Service *** Disconnected from 3cxsrvr-2:5483/IVRServer at 127.0.0.1:5483 ***
    09:46:01.765 CallCtrl::eek:nLegConnected [CM503007]: Call(1): Device joined: sip:108@69.118.56.121:46980
    09:46:00.812 CallCtrl::eek:nLegConnected [CM503007]: Call(1): Device joined: sip:
    09:46:00.796 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: IVR:999@[Dev]
    09:46:00.765 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.108 to [sip:999@ph.mydomain.com]
    The extension in question is 108
  2. jparisi
    Oct 1, 2007
    92
  3. jparisi
    Oct 1, 2007
    92
    Can anybody help with this?
  4. beaver
    Aug 2, 2007
    30
    It's happening the same with my 3cx
    With my 3cx it' heppening exactly the same. You have to restart 3cx to disconect the extension right?
  5. Spitz
    Nov 23, 2007
    26
    have you tried upgrading to the latest build?
  6. jparisi
    Oct 1, 2007
    92
    It was the latest build, I see now one was posted this week.
    Yes, I have to restart the services in order to get the phone reset.
  7. beaver
    Aug 2, 2007
    30
    any results?
    Do you have any changes, becouse mine still working the same I mean having the same issue.
  8. kustura
    Nov 2, 2007
    53
    Are you still able to place calls when the Line Status interface shows the extension as "connected"? My Line Status interface shows wrong status all the time, but I'm still able to place and receive calls. This is for internal extensions.
  9. beaver
    Aug 2, 2007
    30
    yes i can place calls
    Ok in my case i can place calls but when you end the call the timer continue with the issue of the non disconected call. When I upgrade to the last build, I experiment some improvment becouse the problem is not in all the calls, but when you call to 999 or digital receptionist the problem apears. And there is always no audio with 999 or DR. That can be the stun server that i'm using?
  10. kate
    Jan 14, 2008
    18
    I have the same problem with my VOIP line . And I could not call the phone through VOIP line :evil:
  11. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    what i see in your log entries is that you start the 3cx system without en ip adres (local: 127....) en after that you try to call from 108. but the ivr is stil running on 127... maybe is this the problem
  12. jparisi
    Oct 1, 2007
    92
    This is still a problem, even with the latest build.
  13. beaver
    Aug 2, 2007
    30
    The thing that is worst, is that is was happening only with the external lines, but last week happens with an internal line, first i thougt that is has no effects on tha call quality but after 42 hours with the internal line misworking the problem in the audio start and the only way to solve it was the well known restart.
  14. matthijsolislagers
    matthijsolislagers New Member
    140
    I've got exactly the same problem. When you call 999 from an external extension 3CX keeps sending traffic over the DSL line wich is effecting the quality. The only way to solve it is a restart of the voicemail service.
    Is this a know bug? Is it going to be fixed in the next version?
