External Extension on Linksys SPA942
Discussion in 'Windows' started by sinboo50, Mar 16, 2009.
  1. sinboo50
    Feb 28, 2009
    25
    I have an external extension working fine using the current VOIP Softphone. I am having trouble getting the extension to register on the Linksys SPA942. I have viewd the 3CX videos on the topic but I must be missing something.
    SIP Settings
    Stun Server = stun.3cx.com
    enable stun = yes
    My line configuration is attached:
    Also is it necessary to run the proxy client at the same time? I do have that running.
    Thanks in advance.. I know this is elementary but I am a newbie.
    Cheers,
    Bruce
  2. home
    Feb 25, 2009
    31
    I aslo have been having the same problem using a Linksys SPA-921 & 942, soft client works fine, but registration fails on hardware, therefore I would also like to hear from anbody who has this type of setup working.
  3. home
    Feb 25, 2009
    31
    Hi Bruce
    After many hours I have cracked it,
    EXT no.
    SIP Settings
    SIP Transport: TCP
    SIP Port: 5060
    SIP Proxy-Require: Local IP address of 3CX server
    Dial Plan do not alter
    This config registered immediately for me and allowed me to call extensions within our office.
  4. sinboo50
    Feb 28, 2009
    25
    Still working on it here....
    Are you using the current softphone client or just the tunnel client?
  5. home
    Feb 25, 2009
    31
    I am using the "Direct" connection as opposed the "Tunnel" in the 3cx voip client.
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi Pruce
    change stun server to another stun server like stun01.sipphone.com
    change preferred codec to g729 in all your devices
