External extension to external extension – no audio
Discussion in '3CX Phone System - General' started by rmm, May 12, 2010.
  1. rmm
    rmm
    Aug 27, 2009
    23
    Hello.
    Have successfully set up external extensions to 3CX h/o (each on their own VPN – lan to lan) that work completely with audio, functionality, etc. when talking with extensions on the h/o lan.
    However, when two external extensions talk to each other e.g. external>3cx at h/o>external, there is no audio between them.
    Firewall settings must be fine as the external>h/o extension all works fine.
    Any ideas?
    Thank you.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Configure both extensions as "PBX delivers audio=on". It should resolve the problem.
    If you don't want to open support ticket then please provide information in form of "verbose" log from management console and/or a wireshark capture made on PBX host.
    See
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
  3. vpaulo
    Jun 24, 2009
    23
    or simply add route gateway`s into both vpn networks
    For example
    your 3cx server has 192.168.10.10 ip gateway is 192.168.10.1/24 vpn tunel ip is
    your 1-st phone - 192.168.11.11 gw - 192.168.11.1/24
    and 2-nd 192.168.12.12 - 192.168.12.1/24
    in the 1-st network gateway add route like 192.168.10.0/24 192.168.10.1
    If you have vpn topology "star" o "ring`s" you need check where your packet`s are going and where is no direct or back route. Simply you can use traceroute to second extension and see what is the problem.
