- Joined
- Jan 22, 2008
- Messages
- 140
- Reaction score
- 0
In the manual there is there is the following about device configuration:
Where can I set the extension to be external? The option isn't available.
As you can see the help text in the screenshot also mentions this setting but is isn't there.
The 3CX Management Console advanced options settings for this device should have
the following settings:
o Extension/Gateway is external: off (for internal devices) or on (for external
devices)
o PBX delivers audio: on
o Supports Re-Invite: off
o Supports ‘Replaces’ header: off
