External Extensions (Audio one way)
Discussion in '3CX Phone System - General' started by cknott2243, Sep 13, 2010.
  1. cknott2243
    Jul 6, 2010
    49
    hello everyone, I am new to SIP/Voip but have thus far setup 3CX very easily and have calls coming in. A problem I have encountered recently is with external extensions. When someone outside of the office registers an external extension they can all into another internal extension or via a VOIP provider to a land line but when the recipient picks up they can hear the audio but the external extension cannot hear them.
    I obviously thought this was related to RTP not being open somehow but have checked and 9000-9049 (UDP only) is open and allowed through the firewall and when running the FW checker in 3cx I see the following:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <13:26:31>: Phase 1, checking servers connection, please wait...
    <13:26:31>: Stun Checker service is reachable. Phase 1 check passed.
    <13:26:31>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <13:26:31>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <13:26:31>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <13:26:31>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <13:26:31>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <13:26:31>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <13:26:31>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <13:26:33>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
    <13:26:33>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
    <13:26:33>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
    <13:26:33>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
    <13:26:33>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
    <13:26:33>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
    <13:26:33>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
    <13:26:33>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
    <13:26:33>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
    <13:26:33>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
    <13:26:33>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
    <13:26:33>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
    <13:26:33>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
    <13:26:33>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
    <13:26:33>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
    <13:26:33>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
    <13:26:33>: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
    <13:26:33>: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
    <13:26:33>: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
    <13:26:33>: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
    <13:26:33>: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
    <13:26:33>: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
    <13:26:33>: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
    <13:26:33>: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
    <13:26:33>: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
    <13:26:33>: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
    <13:26:33>: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
    <13:26:33>: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
    <13:26:33>: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
    <13:26:33>: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
    <13:26:33>: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
    <13:26:33>: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
    <13:26:33>: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
    <13:26:33>: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
    <13:26:33>: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
    <13:26:33>: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
    <13:26:33>: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
    <13:26:33>: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
    <13:26:33>: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
    <13:26:33>: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
    <13:26:33>: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
    <13:26:33>: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
    <13:26:33>: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
    <13:26:33>: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
    <13:26:33>: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
    <13:26:33>: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
    <13:26:33>: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
    <13:26:33>: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
    <13:26:33>: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
    <13:26:33>: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
    Application exit code is 0
    Does anyone have any idea's for me to look at? I really want to keep 3CX but management is telling me not to waste anymore time with it if I can't get this working correctly.
    Thanks.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Do they have a firewall in between their extension and the internet and is it open for those ports?
    You could also try using the 3cx tunnel which should remove this problem for remote extensions.
  3. leejor
    10,781
    286
    If the remote extension is not receiving audio then you need to look at the router/firewall at that end. Try moving a set to a new location, perhaps trying one at home. If you have more than one set at a location , behind a router, be sure each phone has a unique ports number and that STUN is enabled.
  4. jsadan
    May 3, 2010
    91
    What type of phone are you using?
  5. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    It is often easier to use a tunnel as it removes ALL the issues at remote users' sites. The softphone supports the 3CX tunnel directly. All you need to do is to configure the settings on the softphone, and enable tcp port 5090 at the router connecting the 3CX to the Internet. An alternative is to use the 3CX proxy downloadable here: http://www.3cx.com/downloads/3CXSIPProxyManager9.msi or to use a VPN router - such as a Draytek 2820. The Draytek 2820 comes into its own for providing extensions at remote sites - but only use if the Internet connection is good. All three methods are robust solutions.
    I hope that helps
    Kind regards
    Richard Crabb
