external extensions
Discussion in '3CX Phone System - General' started by aramos, Jan 20, 2007.
  1. aramos
    Jan 10, 2007
    hi i currently hace 3cx working fine in my LAN but i have to connect a phone in a remote location via the internet to my 3cx box. i have full access to my router and i need a list of ports that have to be opened and forwarded to my 3cx box so the external extension would work.
    Please Advice
  2. Watashi_FR
    Dec 5, 2006
    63
    3478TCP, 5060TCP/UDP, the port range set in 3CX for clients, the port range set in 3CX for external lines.
  3. alinvictor
    Jan 26, 2007
    I have the same problem trying to conect to my server from ouside using X-lite on my laptop. I have opened 3478tcp/udp, 5060tcp/udp, 7000-7500udp, 9000-9100udp. Please let me know if there shoud be any special setting on the X-lite I should have set.
    Thanks,
    Alin
  4. Watashi_FR
    Dec 5, 2006
    63
