External extentions call rejected user unknow
Discussion in '3CX Phone System - General' started by rorygennaro, Dec 11, 2007.
  1. rorygennaro
    Nov 7, 2007
    11
    With x-lite but also with 3cx and 3cx voip client I registered one external extention and it can receive calls from 3cx bun when it call to another extention the server reply:
    [CM503011]: Call(4): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 201@82.104.76.230 tid=112d406897003b04 cseq=INVITE contact=208@217.221.45.75:9000 / 2 from(wire)
    and the call is rejected.
  2. mbs1
    Mar 7, 2007
    35
    hi,
    in xlite, in the accounts setting, set the domain field to the internal ip address of the 3cx pbx.
    this should do the trick.
    i have done the same and can confirm that setting up xlite as a remote extension on v5 does work
    mbs
  3. rorygennaro
    Nov 7, 2007
    11
    Ok just do it.
    In 3CX I must check deliver audio to pbx ??
  4. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I face the same issue using '3cx phone for Windows' to connected an (external) extension to 3cx v10 and fixed after set to use tunnel option!
    * the guide: http://www.3cx.com/VOIP/ip-phone-help/LAN-PBX.html
    Renato P
