External Hard phone extension
Discussion in '3CX Phone System - General' started by mmedany, Jan 17, 2008.
  1. mmedany
    Jan 17, 2008
    we have a case in which we have installed the 3CX server in a main office with 5 Grandstream GXP 2000 IP Phones , and we have 6 branches and we need to put one Grandstream GXP 2000 Ip phone at each branch to be connected and registered on the 3CX server at the main office which have a static IP .
    But the remote Hard phones does not work ?? what is the problem and what should we do with that ? and what about outbound proxy??
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    664
    1. You need to "publish" your internal address of 3CX server at external IP of you firewall. Port 5060. Use STUN on you 3cx box. Dont forget to open all ports on firewall for outgoing traffic (not incoming!!!). Or you may open only necessary ports as stated in 3cx manual.
    2. You need to connect you phones to external IP of you office (firewall). Use SIP server address parameter in phone configuration.
    3. Use SNUN on your phones.
    Thats all.
  3. mmedany
    Jan 17, 2008
    we have done all that , the soft phone is working but the hardphone doesn't register
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    SIP Transport: UDP
    Use RFC3581 Symmetric Routing: Yes
    NAT Traversal (STUN): Yes
    this you need for external device
    if this is already done you have to take a closer look to your firewall or router port forwarding.
    if you want i can give u a account on our server for testing. this way you can insure that phones and their network settings are ok.
    the best way to solve problems is to identify the source of problem.
    Andy
