External IP Configuration Not Changing DNS
Discussion in '3CX Phone System - General' started by jhogue1975, Nov 5, 2016.
  1. jhogue1975
    Nov 20, 2015
    29
    I configured a client's system in our office and entered the External IP from my office. Once I moved the system to the customers site and tried changing the External IP so I can reach the PBX from outside the LAN, I noticed it still shows the old Static IP from my office. I called support and they said to change from Static to DHCP, restart all services and then change back to Static IP and restart services again, however, this did not work. I try reaching the PBX from the FQDN and I can't reach it. I waiting several days for full propagation of all DNS servers but still no change. In the PBX the Static IP is staying correct but the DNS is showing my office External IP still so I can't reach the customer's PBX. I am running V15 SP3 and using the 3cx.us:5001.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Hello there,
    Can you send me a PM with your FQDN and the Ip of the old site and the IP of the new site so we can check it from our side?
  3. jhogue1975
    Nov 20, 2015
    29
    I sent you a PM and wanted to make sure you received it.
  4. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Yes i did receive it, i have sent you a reply
