External IPs to be allowed through firewall
Discussion in '3CX Phone System - General' started by LWP, Feb 27, 2017.
  1. LWP
    LWP
    Dec 9, 2016
    Hi Guys
    Do I need to allow the traffic from any other ips than my voip provider? When I lock the policy down to my provider's ip the firewall check fails on "testing 3CX SIP Server" with "full cone test failed", when I allow all sources on the firewall the test passes. Calls are working regardless.
    I have looked at documentation but can't find the answer.
    thanks
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    If you don't use external extensions (or VoIP providers), you don't need to allow new traffic through your inbound connections firewall.
  3. LWP
    LWP
    Dec 9, 2016
    the mentioned "provider" in my post is a Voip provider. When I only allow their ip firewall check fails.
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi LWP,
    Please note some providers send the RTP through differed servers, so if you allow only your provider, also you need to allow all the RTP servers used by your provider.
    May I refer on this link https://www.3cx.com/blog/voip-howto/static-port-mappings/ you can find all the relevant details why "full cone test failed".
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    208
    and firewall test will fail - as you are not allowing traffic from the testing servers.
