External IVR connectivity
Discussion in '3CX Phone System - General' started by microvox, Sep 10, 2007.
  1. microvox
    Aug 24, 2007
    Hello all,
    I have an IVR that already has PRI ISDN connectivity. It can accept direct SIP connections and I would like to have that box handle the oubound calls from my 3CX PBX. Any ideas on how to configure the 3CX PBX to get calls over there?
    Thanks in advance for your help.
