External missed calls are not shown
Discussion in '3CX Phone System - General' started by AndreyP, Jul 13, 2017.
  1. AndreyP
    Apr 11, 2017
    42
    7
    We are using multiple Fanvil X4 phones, all are on the latest 3cx suppored firmware, 3cx is on v15.5.
    Internal missed call is showed ok, but when external call is missed - nothing is shown in phone history.
    Is there a problem with Fanvil comptibility? Pretty annoying issue...
  2. AndreyP
    Apr 11, 2017
    42
    7
    Hey, it looks like this is not related to Fanvil phones at all. Checked with yealink t23p - same story here!
    3CX Support - pleae provide any input here!
    Here is the scope of my discussion with Fanvil support:
    3cx send cancel to my X3S, there have "cause=200" in this cancel.
    In RFC, cause=200 means someone already answer this call, please stop ringing without missed call log.
    But Actully I press cancel, no one answer, so this is 3cx's problem.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,752
    561
    I have a X3 on my desk and when an incoming call arrives and i press reject i do see a missed call.I do not have a X4 currently but i will try to check there as well. What firmware is your phone running and are you using default templates?
    Is it a local extension or remote?
  4. AndreyP
    Apr 11, 2017
    42
    7
    I tested this on X4 and X3s with firmware 2.0.3.3334 with default template.
    Extension is either local or remote. I do not press reject, Caller is just hanging up. Same is for yealink t23p.
  5. AndreyP
    Apr 11, 2017
    42
    7
    Any update? As I said - Fanvil support confirmed it's a 3CX problem and they are waiting for the reply too.
  6. SECOIT GmbH
    Apr 3, 2017
    66
    25
    I gut a big bunch of different phones in my test lab and also a Fanvil X4. On this X4 it shows external missed calls in the history.
    I assigned the extension directly to the SIP trunk, called the external number, hung up after one ring, call was showing in the missed calls list.
    PBX: 15.5.1694
    X4: 2.0.3.3334
    PS: Local phone, same VLAN as the PBX.
  7. AndreyP
    Apr 11, 2017
    42
    7
    Ok, I checked with both remote and local phones. Noone is showing missed external calls.
    What can be the issue in this case?
