External parties can't join conference calls in V12
Discussion in '3CX Phone System - General' started by petarl, Feb 26, 2014.
  1. petarl
    Dec 23, 2010
    9
    I'm having problem with conference calls in V12 - external parties can't join them because 3CX hangs up after they press #.
    Internal extensions can join conference calls without any problem.
    This is from log:
    26-feb-2014 17:00:17.916 L:18.2[Conf]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    26-feb-2014 17:00:17.916 Leg L:18.2[Conf] is terminated: Cause: BYE from 127.0.0.1:40300
    26-feb-2014 17:00:17.912 L:18.2[Conf] got Terminated Recv Req BYE from 127.0.0.1:40300 tid=e936eb00d163af11 Call-ID=OTY1MjRkMWE3ZDRiY2ExMzU5MDI5YWZmNWYyYzgxMzU.:
    BYE sip:0113306513@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40300;branch=z9hG4bK-d8754z-e936eb00d163af11-1---d8754z-;rport=40300
    Max-Forwards: 70
    Contact: <sip:700@127.0.0.1:40300;rinstance=09cd6742ab1ac9b8>
    To: "*81:011xxxxxxx"<sip:0113306513@127.0.0.1:5060;nf=e>;tag=20311847
    Call-ID: OTY1MjRkMWE3ZDRiY2ExMzU5MDI5YWZmNWYyYzgxMzU.
    CSeq: 2 BYE
    User-Agent: 3CX Conference Room
    Reason: SIP;description="User Hung Up"
    Content-Length: 0
    3CX detects that user hangs up, but that is not the case.
    I've even tried with restarting Windows server (2008 R2 on ESXi) but that didn't help.
    I also changed extension numbers, inbound routing and that didn't help either.
    Can anyone suggest any possible solution?
    This worked flawlessly in V11.
    Regards.
  2. petarl
    Dec 23, 2010
    9
    Can anyone help with this?
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,333
    256
    I just tested this and it worked just fine...
    Scheduled a conference with a couple internal users.
    They each received a call at the appropriate time.
    Then I called using my mobile phone. I called the Conference DID we have assigned.
    Then it asked for the conference id, which I entered ^ digits) and hit pound.
    Then it asked to confirm I wanted this conference call. # for NO. * for YES.
    I hit *. Then it asked for my name and any key to continue.
    We are on v12 SP4, Windows 7 (3cx flavor of Webserver)
  4. coreybrett
    Apr 12, 2010
    72
    I'm having the same exact issue with my v12 system.
  5. petarl
    Dec 23, 2010
    9
    SP5 didn't help, either.
    3cx hangs up on external users when they select conference number.
  6. davidc@allpax.com
    Jun 25, 2014
    15
    I am having the same problem. Did you ever solve this?
  7. petarl
    Dec 23, 2010
    9
    Not yet. I have yet to apply SP6 and to try again conference calls tomorrow. I'll report results here.
  8. petarl
    Dec 23, 2010
    9
    I've updated 3cx to V12 SP6 and that didn't help either. Does anyone have any idea why this is happening?
  9. petarl
    Dec 23, 2010
    9
    I've used WireShark to analyze this problem. 3CX sends BYE SIP request to Bero ISDN gateway after external party presses 'pound' character (#). Can anyone try to explain why is this happening?
  10. cdrichla
    May 25, 2008
    33
    3CX Support had me change the MSADDRFC2833FORINBANDDTMF setting in custom parameters to 0. They think it's an in/out band RFC2833 issue from the PSTN. In my case it's a Sangoma PRI card. Changing this setting didn't help and I also upgraded to SP6 which didn't help either. I'm currently trying to capture the RTP stream to try to hear audibly what is going on with the DTMF signaling. According to the Sangoma logs so far, only one # is being sent. 3CX says that if 2 #s are sent, the second one is interpreted as disconnect request.
  11. factorypolaris
    Jun 27, 2014
    Thanks for keeping this post alive. I am having the same issue on a V12 system.
    I think my issue may be in the firewall. After 2 days of testing, I was able to get it to work once this morning... Then without changing anything, it would not work again. It's very strange. Firewall logs are not reporting any blocked traffic for this service.
    Like you I am working right now to get this resolved. If I come up with anything, I will re-post.
    -Chris
  12. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Its a simple case of "user error" (the reason for the quotes is the user probably is dialing the calls the same speed as normal but 3cx has a different reaction while trying to connect to the conference) The users are pushing pound twice...Tell the user to dial the conference call code and pound but do it really slowly. I'd be willing to bet if you look in the wireshark log you will see the pound key pushed miltple times. You will see this indicated by DTMF in the wireshark log. You have already pointed out via the server activity log the hangup is coming from the user... 3cx also answered the question according to Baronets post but since they most likely do not use the conference very often they wouldnt know to tell you to dial very slow when trying to connect to a conference. I hope this helps make a few test calls joining into a conference and post here what your results are....
    Postby petarl » Wed Feb 26, 2014 10:05 am
    This is from log:
    Max-Forwards: 70
    CSeq: 2 BYE
    Content-Length: 0
  13. factorypolaris
    Jun 27, 2014
    A dialing issue is not the case for me. I have tried every dialing method, slow, really slow, long pause, no pause, etc and still the call drops. If indeed it is a dialing issue, then the whole conference thing is 100% non usable as I would spend more time training people on how to dial in for a conference than actually having the conference itself. Especially when I can't get it to work myself as the network admin. (LOL)
    I am beginning to think there is some type of a bug. With multiple people reporting the same issue all with V12 and everything else working fine, I don't think there is a firewall issue. However, I have tried multiple configurations on the firewall with no luck either.
    From the deskphone, I can create a conference between two external callers with no issue. That works great. The only issue is that first menu when calling in to ext 700. It happens whether the inbound rule directs them to 700 OR they are transferred to 700 via a desk-phone.
    I sure hope someone can offer some additional insight to this. Thanks for reading and have a great day!
    -Chris
  14. jpillow
    Jun 20, 2011
    1,342
    I had client experiencing the exact same thing a few months back turns out they were pushing that button twice.... Post a log while attempting to connect to the conference bridge.
  15. Mitchellb
    Jan 21, 2014
    11
    Hi Guys, having the same issue on my side and I can assure you that I am NOT pressing # twice - even confirmed by looking at my mobile which shows 1 #. Any ideas? A client has an important international conference tomorrow and If i cant get this right, I'm going to be in a bit of trouble... :(
  16. intellegens
    Jun 19, 2013
    18
    Are you using any voice gateway? If so, what model?
    What is the make and model of your firewall - hopefully, it is not a Sonicwall
  17. Mitchellb
    Jan 21, 2014
    11
    I'm not using a Gateway - I have a Native SIP Trunk on the 3CX.
  18. intellegens
    Jun 19, 2013
    18
    This is probably redundant but I always like to get it out of the way. Do all ports pass the firewall checker test?
  19. Mitchellb
    Jan 21, 2014
    11
    Hi there, thanks for your reply.
    The issue is inconsistent (but cuts off more times than not). If all ports were open/closed I am guessing it would either always present an issue, or not. In this case it is inconsistent. I am going to run a Wireshark trace and send over to the support team per their suggestion.
    thanks
  20. Ryan.Phytertek
    Jul 22, 2014
    I am having the same issue with V12 sp 6
    We're definitely not pressing # twice...
    I'm hoping there is a fix for this soon... :(
