External Signalisation
Discussion in '3CX Phone System - General' started by renesidler, Dec 14, 2007.
  1. renesidler
    Sep 19, 2006
    Does anyone know of a product to implement an extra signalisation like blinking lights....
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    please explain in more details,
    regards
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    it depends on you electronical capabilitys and how much u want to invest.
    - you can use a phone like grandstream GXP series (or other cheaper) and couple a relais via a transistor to the ring indicator led.
    you can switch nearly anything over the relais (lamp / horn / flashing strobe / a fogger ) :)
    simple and about 100$ (not good for resale)
    or
    you can use a microdevice like PIC from Microdevice with a ethernet port and ip stack and let this device login as second Device in BPX or snief the port to find out that the port is ringing and swich a relais from this device.
    not so simple but not bigger then half size of a box of cigaretts.
    good for resale.
    about 100$ each unit but i think you have to pay some tousend $ for enginering and programming. (5.000 $ ?? not shure)
    Andy
