External SIP Extension Rings on direct Sip calls but hangs up immediately when picked up
Discussion in '3CX Phone System - General' started by Thomas6, Sep 19, 2017.
  1. Thomas6
    Sep 19, 2017
    My Infrastructure:
    3CX PBX Edition 15.5.5 installed from debian-8.6.0-amd64-netinst-3cx.iso
    with all Updates
    3CX Softphone on iOS
    DNS Server is on the same System
    Im not sure if my dns configuration is correct.
    this is the entry in the dnszone file.
    _______________________________________________
    ; BIND reverse data file for empty rfc1918 zone
    ; DO NOT EDIT THIS FILE - it is used for multiple zones.
    ; Instead, copy it, edit named.conf, and use that copy.
    $TTL 86400
    @ IN SOA debian.local. root.localhost. (
    1 ; Serial
    604800 ; Refresh
    86400 ; Retry
    2419200 ; Expire
    86400 ) ; Negative Cache TTL
    IN A 10.0.1.253
    @ IN NS localhost.
    sip.debian.local IN A 10.0.1.253
    _sip._udp.debian.local. IN SRV 20 1 5060 sip.debian.local.
    __________________________________________________________
    the respons from nslookup is:
    nslookup -q=SRV _sip._udp.debian.local
    Server: 127.0.0.1
    Address: 127.0.0.1#53
    _sip._udp.debian.local service = 20 1 5060 sip.debian.local.
    The sip settings in the 3cx system allows in and out
    I get alway the following error message: (Register/ Unregister)
    Does anyone knows how to solve this problem.
    Best Regards Thomas
