External user with SPA922 behind D-Link
Discussion in 'Windows' started by jr3151006, Jul 30, 2010.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    Hi all,
    I installed 3CX on my server (Windows 2008), redirected on my ADSL MODEM (LG LNAR-1000) the ports 5060 UDP and from 9000 to 9049 UDP to my server.
    The first extension ('1000') is inside my office/network working fine on Cisco SPA-922, my second extension '1001' I use on my HTC (using PortGo sip client) over GSM or Wi-fi. I´m able to call each other fine! No problems here!
    Help
    I tryied to install another extension ('1002') on Cisco SPA-942 wich is behind a D-Link DSL-500B, without success (audio).
    Question
    Can anyone who has external users with Cisco devices to tell me what ports needed to be configured/redirected on D-Link router or in the Cisco??
    My current SPA-942 configuration on a customer
    NAT Mapping Enable = yes
    NAT Keep Alive Enable = yes
    NAT Kepp Alive MSG = $NOTIFY
    NAT Kepp Alive Dest = $PROXY
    SIP Transport = UDP
    SIP Port = 5060
    Proxy = valid_ip_3cxServer:5060
    Register = yes
    User id = 1002
    Password = ********
    Use Auth ID = NO
    11,277
    360
    Have you set up ext 1001 to use STUN?
